Was du brauchst
Using a scribe, pry the edges of the back cover from all sides [1].
Lift the back cover from the computer [2].
Disconnect the battery cable from the connector on the system board [1].
Remove the screws that secure the battery to the computer [2].
Lift and remove the battery from the computer [3].
Pull the retention clips from the memory module until it pops up. [1]
Remove the memory module from the connector on the system board. [2]
