Was du brauchst
Loosen the M2.5x2+3.5 captive screws that secure the base cover to the computer [1].
Pry the base cover from the edge [2].
Lift the base cover away from the computer
Disconnect the battery cable from the connector on the system board [1].
Remove the M2x3L screws that secure the battery to the computer [2].
Remove the M3x3L screw that secures the SSD to the computer [1].
Slide and lift the SSD from the computer [2].
Eine weitere Person hat diese Anleitung absolviert.
