Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide the battery release latches until they click into place.
    • Slide the battery release latches until they click into place.
      • Slide the battery out of the battery bay.
  2. Open the display all the way so that it rests flat on your work surface.
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
      • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
      • Rotate the keyboard connector latch upward to release the keyboard cable.
        • Slide the keyboard cable out of the keyboard connector.
Abschluss
Johnathan Hammond
Mitglied seit 28.02.2018
35.878 Reputation
408 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 63
