Zum Hauptinhalt wechseln
Dell Vostro 15 Memory Module Replacement
Was du brauchst
  1. Dell Vostro 15 Memory Module Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 15 Memory Module Replacement, Hinge Cover: Schritt 2, Bild 1 von 1
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
  3. Dell Vostro 15 Memory Module Replacement, KeyBoard: Schritt 3, Bild 1 von 1
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
  4. Dell Vostro 15 Memory Module Replacement, Memory Module: Schritt 4, Bild 1 von 1
    • Lift the memory module cover But Do Not Remove It.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module from the connector.
Abschluss
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 76
