Zum Hauptinhalt wechseln
Dell Vostro 1500 Keyboard Replacement
Was du brauchst
  1. Dell Vostro 1500 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: Schritt 5, Bild 2 von 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: Schritt 5, Bild 3 von 3
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Vostro 1500 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Vostro 1500 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: Schritt 8, Bild 1 von 3 Dell Vostro 1500 Keyboard Replacement: Schritt 8, Bild 2 von 3 Dell Vostro 1500 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Pull the connector toward the screen.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 1-3, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-3, Catania Fall 2016
UMASSD-CATANIA-F16S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 965
