Zum Hauptinhalt wechseln
Dell Vostro 1540 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 1540 Hard Drive Replacement, Unlocking the Battery: Schritt 1, Bild 1 von 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 1540 Hard Drive Replacement, Sliding the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 1540 Hard Drive Replacement, KeyBoard: Schritt 3, Bild 1 von 1
    • Pry up to release the top four snaps securing the keyboard to the computer.
  4. Dell Vostro 1540 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Flip the keyboard over and lay it on the palm rest
  5. Dell Vostro 1540 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the keyboard cable from the system board.
  6. Dell Vostro 1540 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the keyboard from the computer.
  7. Dell Vostro 1540 Hard Drive Replacement, Palm Rest: Schritt 7, Bild 1 von 1
    • Remove the screws that secure the bottom base.
  8. Dell Vostro 1540 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Flip the computer around and disconnect the power board cable (1) and the touchpad cable (2).
  9. Dell Vostro 1540 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Remove the screws that secure the palm rest to the computer
  10. Dell Vostro 1540 Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Pry up the palm rest using a plastic scribe to release all the snaps on the bottom, left, and right sides of the palm rest. Once all the snaps have been released, lift up the palm rest from the computer and remove.
  11. Dell Vostro 1540 Hard Drive Replacement, Hard Drive: Schritt 11, Bild 1 von 1
    • Slide the hard drive and lift it out of the computer.
  12. Dell Vostro 1540 Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Remove the screws that secure the hard drive bracket and detach it from the hard drive.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 22
Insgesamt: 1,953
