Zum Hauptinhalt wechseln
Einleitung
The RAM in a computer plays an important job in multitasking. If your computer is slow when multiple programs are open, the RAM might need to be replaced. This guide instructs you how to replace the RAM in a Dell Vostro 1700.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Dell Vostro 1700 RAM Replacement, Keyboard: Schritt 1, Bild 1 von 3 Dell Vostro 1700 RAM Replacement, Keyboard: Schritt 1, Bild 2 von 3 Dell Vostro 1700 RAM Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: Schritt 2, Bild 1 von 1
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: Schritt 3, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: Schritt 4, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 4, Bild 2 von 2
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: Schritt 5, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 5, Bild 2 von 2
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: Schritt 6, Bild 1 von 3 Dell Vostro 1700 RAM Replacement, RAM: Schritt 6, Bild 2 von 3 Dell Vostro 1700 RAM Replacement, RAM: Schritt 6, Bild 3 von 3
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: Schritt 7, Bild 1 von 3 Dell Vostro 1700 RAM Replacement: Schritt 7, Bild 2 von 3 Dell Vostro 1700 RAM Replacement: Schritt 7, Bild 3 von 3
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: Schritt 8, Bild 1 von 3 Dell Vostro 1700 RAM Replacement: Schritt 8, Bild 2 von 3 Dell Vostro 1700 RAM Replacement: Schritt 8, Bild 3 von 3
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: Schritt 9, Bild 1 von 2 Dell Vostro 1700 RAM Replacement: Schritt 9, Bild 2 von 2
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: Schritt 10, Bild 1 von 3 Dell Vostro 1700 RAM Replacement: Schritt 10, Bild 2 von 3 Dell Vostro 1700 RAM Replacement: Schritt 10, Bild 3 von 3
    • Lift the RAM chip up and out of the slot.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Nathan Valm
735 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 5
Insgesamt: 782
