Zum Hauptinhalt wechseln
Einleitung
This guide will instruct you on how to remove the Wi-Fi card from the Dell Vostro 1700 laptop. The Wi-Fi card controls all of the wireless internet functionality of the laptop.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two Phillips #1 screws from the Wi-Fi card cover on the bottom of the laptop. Remove the two Phillips #1 screws from the Wi-Fi card cover on the bottom of the laptop.
    • Remove the two Phillips #1 screws from the Wi-Fi card cover on the bottom of the laptop.
  2. Lift up on the cover and remove it. Lift up on the cover and remove it. Lift up on the cover and remove it.
    • Lift up on the cover and remove it.
  3. Use the spudger to lift the small wires connecting to the Wi-Fi card. Use the spudger to lift the small wires connecting to the Wi-Fi card. Use the spudger to lift the small wires connecting to the Wi-Fi card.
    • Use the spudger to lift the small wires connecting to the Wi-Fi card.
  4. Use your thumbs to push the retaining clips upward to release the card. Use your thumbs to push the retaining clips upward to release the card.
    • Use your thumbs to push the retaining clips upward to release the card.
  5. Pull the card outward and then upward to remove it from the slot. Pull the card outward and then upward to remove it from the slot. Pull the card outward and then upward to remove it from the slot.
    • Pull the card outward and then upward to remove it from the slot.
Abschluss
Nathan Valm
678 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 117
