Einleitung
The battery gives power to the laptop so if your computer is not powering up you will need to replace the battery. This guide will show you how to replace the battery but be careful when replacing it because it can still hold a charge.
  1. Make certain that the power to your laptop is off. Press and slide the two buttons outwards and away from the battery.
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Slide the battery away and parallel from the laptop.
    • Slide the battery away and parallel from the laptop.
  4. Remove the battery from the slot.
    • Remove the battery from the slot.
Abschluss
Tangxiao Sun
419 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 Mitglieder
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 85
