Einleitung
The fan helps the laptop remove the heat it produces and keeps your laptop from overheating. If your computer keeps over heating you will need to replace the fan. This guide will walk you through on how to replace the fan using only a #1 Philips head screwdriver.
Was du brauchst
Lift back cover from the groove on the left side of the cover next to the symbol.
Unclip the power supply by pulling the cable directly up and out of the socket.
Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
