Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Slide both battery latches to the open position.
    • Slide both battery latches to the open position.
    • Slide the battery out of the battery bay.
  2. Loosen the five screws that secure the hard-drive compartment cover.
    • Loosen the five screws that secure the hard-drive compartment cover.
    • Remove the cover and set it aside.
  3. Remove the three screws that secure the hard drive to the computer.
    • Remove the three screws that secure the hard drive to the computer.
    • One screw is attached to a metal tab on the metal base of the hard drive, and the other two screws are attached to the metal base.
    • Disconnect the hard drive cable connector from the motherboard.
    • Pull the mylar tab to release the hard drive.
    • Lift the hard drive and the hard drive cable out of the computer. You may find it easier to lift the hard drive starting from the side located opposite from the hard drive's connection to the hard drive cable.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
Johnathan Hammond
37.298 Reputation
408 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
21 Mitglieder
1.824 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 7
Insgesamt: 260
