Zum Hauptinhalt wechseln
Dell Vostro 1710 Keyboard Replacement
Was du brauchst
  1. Dell Vostro 1710 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Vostro 1710 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Vostro 1710 Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
  5. Dell Vostro 1710 Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Vostro 1710 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
  6. Dell Vostro 1710 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Vostro 1710 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 3mm Philips #1 head screws.
  7. Dell Vostro 1710 Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Vostro 1710 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Gently lift up the keyboard to remove.
    • Flip it over as it shown in the picture.
  8. Dell Vostro 1710 Keyboard Replacement: Schritt 8, Bild 1 von 2 Dell Vostro 1710 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Lift the black tab that the keyboard is plugged into.
  9. Dell Vostro 1710 Keyboard Replacement: Schritt 9, Bild 1 von 2 Dell Vostro 1710 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Pull directly outwards to remove the keyboard completely.
Abschluss
Tangxiao Sun
496 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 672
