Einleitung
The keyboard helps user input characters and functions when using the laptop. If your key does not function well, you might need to replace the keyboard. This guide will walk you through on how to replace the keyboard.
Was du brauchst
Use the plastic opening tool to loosen the plastic hinge cover that is located above the keyboard.
Remove plastic hinge cover by gently lifting up the cover with a plastic opening tool from one side to the other.
Gently lift up the keyboard to remove.
Flip it over as it shown in the picture.
