Einleitung
RAM is needed for a computer to function. If your computer is crashing you may have old or damaged RAM. It can be damaged by static electricity and if it is not removed or inserted correctly. Adding more RAM to your computer can improve its performance drastically.
Was du brauchst
Lift back cover from the groove on the left side of the cover next to the symbol.
Repeat the same process by pushing the bottom metal tabs outward and away from the RAM.
