Einleitung
In this guide, we will be showing how to remove and replace the Memory Modules.
Was du brauchst
Slide the release latches outwards to unlock the battery and lift the battery to remove it from the computer.
Loosen the screw that secures the access panel and remove it from the computer.
Pry the securing clips away from the memory module until it pops up. Remove the memory module from its socket on the system board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
