Zum Hauptinhalt wechseln
Dell Vostro 3300 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 3300 Hard Drive Replacement, Sliding the Latch: Schritt 1, Bild 1 von 1
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3300 Hard Drive Replacement, Sliding the Latch: Schritt 2, Bild 1 von 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3300 Hard Drive Replacement, Slide the Battery: Schritt 3, Bild 1 von 1
    • Slide the battery and remove it from the computer.
  4. Dell Vostro 3300 Hard Drive Replacement, Base Cover: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer.
  5. Dell Vostro 3300 Hard Drive Replacement, Lifting the Base Cover: Schritt 5, Bild 1 von 1
    • Lift up the base cover and remove it from the computer.
  6. Dell Vostro 3300 Hard Drive Replacement, Remove the Screws: Schritt 6, Bild 1 von 1
    • Remove the screws that secure the hard-drive assembly to the computer.
  7. Dell Vostro 3300 Hard Drive Replacement, Lifting the Hard-Drive Assembly: Schritt 7, Bild 1 von 1
    • Pull up on the black hard-drive release tab and lift the hard-drive assembly up and away from the computer.
  8. Dell Vostro 3300 Hard Drive Replacement, Remove the Screws: Schritt 8, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  9. Dell Vostro 3300 Hard Drive Replacement, Remove the Hard-Drive Adapter: Schritt 9, Bild 1 von 1
    • Remove the hard-drive adapter from the hard-drive assembly.
  10. Dell Vostro 3300 Hard Drive Replacement, Lifting the Hard-Drive Bracket: Schritt 10, Bild 1 von 1
    • Lift the hard-drive bracket up and away from the hard drive.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,213
