Einleitung
In this guide, we will be showing you how to remove and replace the Battery.
Was du brauchst
Remove the screw that secures the access panel to the computer.
Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
Lift the clip to release the keyboard cable and disconnect it from the computer.
Disconnect the battery cable from the system board.
Remove the screws that secure the battery to the system board.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
