Zum Hauptinhalt wechseln
Dell Vostro 3360 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: Schritt 1, Bild 1 von 1
    • Remove the screw that secures the keyboard to the chassis.
  2. Dell Vostro 3360 Hard Drive Replacement, Prying the Keyboard: Schritt 2, Bild 1 von 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  3. Dell Vostro 3360 Hard Drive Replacement, Flipping the Keyboard: Schritt 3, Bild 1 von 1
    • Flip the keyboard over and lay it on the palmrest.
  4. Dell Vostro 3360 Hard Drive Replacement, Lifting the Clip: Schritt 4, Bild 1 von 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  5. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: Schritt 5, Bild 1 von 1
    • Remove the screw that secures the access panel to the computer.
  6. Dell Vostro 3360 Hard Drive Replacement, Remove the Access Panel: Schritt 6, Bild 1 von 1
    • Remove the access panel from the computer.
  7. Dell Vostro 3360 Hard Drive Replacement, Display-Hinge Cover: Schritt 7, Bild 1 von 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Hard Drive Replacement, Remove the Display Hinge Cover: Schritt 8, Bild 1 von 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Hard Drive Replacement, Prying the Rubber Pads: Schritt 9, Bild 1 von 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: Schritt 10, Bild 1 von 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the Board Cable: Schritt 11, Bild 1 von 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the LED Cable: Schritt 12, Bild 1 von 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: Schritt 13, Bild 1 von 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Hard Drive Replacement, Prying the Edges of the Palm-Rest: Schritt 14, Bild 1 von 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Hard Drive Replacement, Lifting the Palm Rest: Schritt 15, Bild 1 von 1
    • Lift the palm-rest up and away from the computer.
  16. Dell Vostro 3360 Hard Drive Replacement, Hard Drive: Schritt 16, Bild 1 von 1
    • Remove the screws that secure the hard drive to the computer.
  17. Dell Vostro 3360 Hard Drive Replacement: Schritt 17, Bild 1 von 1
    • Lift the hard drive to disconnect the hard-drive cable
  18. Dell Vostro 3360 Hard Drive Replacement: Schritt 18, Bild 1 von 1
    • Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
  19. Dell Vostro 3360 Hard Drive Replacement: Schritt 19, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 3,214
