Einleitung
In this guide, we will show you how to remove and replace the Memory Module.
Was du brauchst
Slide the left and the right battery release latches to the unlock position.
Pry up the memory door near the screw hole, lift and remove it.
Pry the retention clips away from the memory module until it pops up.
Remove the memory module from its connector on the system board.
Fast fertig!
Ziellinie
