Einleitung
In this guide, we will show you how to remove and replace the Optical Drive.
Was du brauchst
Slide the left and the right battery release latches to the unlock position.
Pry up the memory door near the screw hole, lift and remove it.
Remove the screw that secures the optical drive to the computer.
Remove the optical drive bracket from the optical drive module.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
