Zum Hauptinhalt wechseln
Dell Vostro 3450 System Board Replacement
Was du brauchst
  1. Dell Vostro 3450 System Board Replacement, Unlocking the Battery: Schritt 1, Bild 1 von 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 System Board Replacement, Removing the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 System Board Replacement, Press the ExpressCard: Schritt 3, Bild 1 von 1
    • Press the ExpressCard to release it from the computer.
  4. Dell Vostro 3450 System Board Replacement, Slide the ExpressCard: Schritt 4, Bild 1 von 1
    • Slide the ExpressCard out of the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 System Board Replacement, Prying the Keyboard: Schritt 5, Bild 1 von 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  6. Dell Vostro 3450 System Board Replacement, Prying the Keyboard retainer: Schritt 6, Bild 1 von 1
    • Pry up the second keyboard retainer.
  7. Dell Vostro 3450 System Board Replacement, Pry up the Keyboard Retainer: Schritt 7, Bild 1 von 1
    • Pry up the third keyboard retainer.
  8. Dell Vostro 3450 System Board Replacement, Prying the Retainer: Schritt 8, Bild 1 von 1
    • Pry up the fourth keyboard retainer.
  9. Dell Vostro 3450 System Board Replacement, Pull up the Keyboard: Schritt 9, Bild 1 von 1
    • Pull up the keyboard from the palm rest.
  10. Dell Vostro 3450 System Board Replacement, Release the Latch: Schritt 10, Bild 1 von 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
  11. Dell Vostro 3450 System Board Replacement, Loosen the Screw: Schritt 11, Bild 1 von 1
    • Loosen the screw that secures the memory door.
  12. Dell Vostro 3450 System Board Replacement, Removing the Memory Door: Schritt 12, Bild 1 von 1
    • Pry up the memory door near the screw hole, lift and remove it.
  13. Dell Vostro 3450 System Board Replacement, Remove the Screw: Schritt 13, Bild 1 von 1
    • Remove the screw that secures the optical drive to the computer.
  14. Dell Vostro 3450 System Board Replacement, Prying the Drive: Schritt 14, Bild 1 von 1
    • Gently pry the optical drive out of the computer.
  15. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 15, Bild 1 von 1
    • Remove the screws that secure the optical drive bracket.
  16. Dell Vostro 3450 System Board Replacement, Removing the Optical Drive: Schritt 16, Bild 1 von 1
    • Remove the optical drive bracket from the optical drive module.
  17. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 17, Bild 1 von 1
    • Remove the screws in the battery compartment.
  18. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 18, Bild 1 von 1
    • Remove the screws in the optical drive compartment.
  19. Dell Vostro 3450 System Board Replacement, Remove the Rubber: Schritt 19, Bild 1 von 1
    • Remove the rubber from the bottom base on the right side.
  20. Dell Vostro 3450 System Board Replacement, Remove the Rubber: Schritt 20, Bild 1 von 1
    • Remove the rubber from the bottom base on the left side.
  21. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 21, Bild 1 von 1
    • Remove all the screws from the bottom base.
  22. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 22, Bild 1 von 1
    • Flip the computer around and remove the screws that secures the palm rest.
  23. Dell Vostro 3450 System Board Replacement, Release the Latches: Schritt 23, Bild 1 von 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  24. Dell Vostro 3450 System Board Replacement, Release the Latch: Schritt 24, Bild 1 von 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  25. Dell Vostro 3450 System Board Replacement, Disconnecting the Key Cable: Schritt 25, Bild 1 von 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  26. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: Schritt 26, Bild 1 von 1
    • Pry up the right side of the palm rest.
  27. Dell Vostro 3450 System Board Replacement, Prying the Palm Rest: Schritt 27, Bild 1 von 1
    • Pry up the left side of the palm rest.
  28. Dell Vostro 3450 System Board Replacement, Prying the Sides: Schritt 28, Bild 1 von 1
    • Pry up the sides of the palm rest and remove it from the computer.
  29. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 29, Bild 1 von 1
    • Remove the screws that secure the hinge cover.
  30. Dell Vostro 3450 System Board Replacement, Press Down on the Hooks: Schritt 30, Bild 1 von 1
    • Press down on the hooks highlighted in the image.
  31. Dell Vostro 3450 System Board Replacement, Removing the Hinge Cover: Schritt 31, Bild 1 von 1
    • Flip the computer around and remove the hinge cover from the side.
  32. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 32, Bild 1 von 1
    • Remove the screws that secure the display hinge.
  33. Dell Vostro 3450 System Board Replacement, Loosen the Screw: Schritt 33, Bild 1 von 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  34. Dell Vostro 3450 System Board Replacement, Disconnecting the LVDS Cable: Schritt 34, Bild 1 von 1
    • Disconnect the LVDS cable from the system board.
  35. Dell Vostro 3450 System Board Replacement, Disconnecting the Wireless Cables: Schritt 35, Bild 1 von 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  36. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 36, Bild 1 von 1
    • Remove the screws that secure the left hinge.
  37. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 37, Bild 1 von 1
    • Remove the screws that secure the right hinge.
  38. Dell Vostro 3450 System Board Replacement, Lifting the Display Assembly: Schritt 38, Bild 1 von 1
    • Lift the display assembly and remove it from the computer.
  39. Dell Vostro 3450 System Board Replacement, Remove the Screw: Schritt 39, Bild 1 von 1
    • Remove the screw that secures the WLAN card.
  40. Dell Vostro 3450 System Board Replacement, Pull the Card: Schritt 40, Bild 1 von 1
    • Pull the WLAN card straight out of its socket and remove it.
  41. Dell Vostro 3450 System Board Replacement, Release the Latch: Schritt 41, Bild 1 von 1
    • Release the latch on the system board and then disconnect the VGA cable.
  42. Dell Vostro 3450 System Board Replacement, Remove the Screw: Schritt 42, Bild 1 von 1
    • Remove the screw that secures the VGA board.
  43. Dell Vostro 3450 System Board Replacement, Remove the VGA Board: Schritt 43, Bild 1 von 1
    • Remove the VGA board from the chassis.
  44. Dell Vostro 3450 System Board Replacement, Disconnect the System Fan Cable: Schritt 44, Bild 1 von 1
    • Disconnect the system fan cable from the system board.
  45. Dell Vostro 3450 System Board Replacement, Remove the Screw: Schritt 45, Bild 1 von 1
    • Remove the screw that secures the system fan.
  46. Dell Vostro 3450 System Board Replacement, Remove the System Fan: Schritt 46, Bild 1 von 1
    • Remove the system fan from the bottom base module.
  47. Dell Vostro 3450 System Board Replacement, Disconnect the DC-in Cable: Schritt 47, Bild 1 von 1
    • Disconnect the DC-in cable connector from the system board.
  48. Dell Vostro 3450 System Board Replacement, Disconnecting the Speaker Cable: Schritt 48, Bild 1 von 1
    • Disconnect the speaker cable from the system board.
  49. Dell Vostro 3450 System Board Replacement, Remove the Screws: Schritt 49, Bild 1 von 1
    • Remove the screws that secures the system board.
  50. Dell Vostro 3450 System Board Replacement, Disconnecting the System Board: Schritt 50, Bild 1 von 1
    • Disconnect the system board from the Input/Output panel.
  51. Dell Vostro 3450 System Board Replacement, Remove the System Board: Schritt 51, Bild 1 von 1
    • Lift and remove system board from the chassis.
Ziellinie
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 423
