Zum Hauptinhalt wechseln
Dell Vostro 3450 VGA Board Replacement
Was du brauchst
  1. Dell Vostro 3450 VGA Board Replacement, Unlocking the Battery: Schritt 1, Bild 1 von 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 VGA Board Replacement, Removing the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 VGA Board Replacement, Prying the Keyboard: Schritt 3, Bild 1 von 1
    • Press the keyboard down. Pry the keyboard with the use of a flat-head screwdriver towards the display to reveal the first keyboard retainer.
  4. Dell Vostro 3450 VGA Board Replacement, Prying the Keyboard retainer: Schritt 4, Bild 1 von 1
    • Pry up the second keyboard retainer.
  5. Dell Vostro 3450 VGA Board Replacement, Pry up the Keyboard Retainer: Schritt 5, Bild 1 von 1
    • Pry up the third keyboard retainer.
  6. Dell Vostro 3450 VGA Board Replacement, Prying the Retainer: Schritt 6, Bild 1 von 1
    • Pry up the fourth keyboard retainer.
  7. Dell Vostro 3450 VGA Board Replacement, Pull up the Keyboard: Schritt 7, Bild 1 von 1
    • Pull up the keyboard from the palm rest.
  8. Dell Vostro 3450 VGA Board Replacement, Release the Latch: Schritt 8, Bild 1 von 1
    • Release the latch on the system board connector, then disconnect the keyboard cable.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  9. Dell Vostro 3450 VGA Board Replacement, Loosen the Screw: Schritt 9, Bild 1 von 1
    • Loosen the screw that secures the memory door.
  10. Dell Vostro 3450 VGA Board Replacement, Removing the Memory Door: Schritt 10, Bild 1 von 1
    • Pry up the memory door near the screw hole, lift and remove it.
  11. Dell Vostro 3450 VGA Board Replacement, Remove the Screw: Schritt 11, Bild 1 von 1
    • Remove the screw that secures the optical drive to the computer.
  12. Dell Vostro 3450 VGA Board Replacement, Prying the Drive: Schritt 12, Bild 1 von 1
    • Gently pry the optical drive out of the computer.
  13. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 13, Bild 1 von 1
    • Remove the screws that secure the optical drive bracket.
  14. Dell Vostro 3450 VGA Board Replacement, Removing the Optical Drive: Schritt 14, Bild 1 von 1
    • Remove the optical drive bracket from the optical drive module.
  15. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 15, Bild 1 von 1
    • Remove the screws in the battery compartment.
  16. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 16, Bild 1 von 1
    • Remove the screws in the optical drive compartment.
  17. Dell Vostro 3450 VGA Board Replacement, Remove the Rubber: Schritt 17, Bild 1 von 1
    • Remove the rubber from the bottom base on the right side.
  18. Dell Vostro 3450 VGA Board Replacement, Remove the Rubber: Schritt 18, Bild 1 von 1
    • Remove the rubber from the bottom base on the left side.
  19. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 19, Bild 1 von 1
    • Remove all the screws from the bottom base.
  20. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 20, Bild 1 von 1
    • Flip the computer around and remove the screws that secures the palm rest.
  21. Dell Vostro 3450 VGA Board Replacement, Release the Latches: Schritt 21, Bild 1 von 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  22. Dell Vostro 3450 VGA Board Replacement, Release the Latch: Schritt 22, Bild 1 von 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  23. Dell Vostro 3450 VGA Board Replacement, Disconnecting the Key Cable: Schritt 23, Bild 1 von 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  24. Dell Vostro 3450 VGA Board Replacement, Prying the Palm Rest: Schritt 24, Bild 1 von 1
    • Pry up the right side of the palm rest.
  25. Dell Vostro 3450 VGA Board Replacement, Prying the Palm Rest: Schritt 25, Bild 1 von 1
    • Pry up the left side of the palm rest.
  26. Dell Vostro 3450 VGA Board Replacement, Prying the Sides: Schritt 26, Bild 1 von 1
    • Pry up the sides of the palm rest and remove it from the computer.
  27. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 27, Bild 1 von 1
    • Remove the screws that secure the hinge cover.
  28. Dell Vostro 3450 VGA Board Replacement, Press Down on the Hooks: Schritt 28, Bild 1 von 1
    • Press down on the hooks highlighted in the image.
  29. Dell Vostro 3450 VGA Board Replacement, Removing the Hinge Cover: Schritt 29, Bild 1 von 1
    • Flip the computer around and remove the hinge cover from the side.
  30. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 30, Bild 1 von 1
    • Remove the screws that secure the display hinge.
  31. Dell Vostro 3450 VGA Board Replacement, Loosen the Screw: Schritt 31, Bild 1 von 1
    • Loosen the screw that secures the low-voltage differential signaling (LVDS) cable.
  32. Dell Vostro 3450 VGA Board Replacement, Disconnecting the LVDS Cable: Schritt 32, Bild 1 von 1
    • Disconnect the LVDS cable from the system board.
  33. Dell Vostro 3450 VGA Board Replacement, Disconnecting the Wireless Cables: Schritt 33, Bild 1 von 1
    • Disconnect the wireless local area network (WLAN) antenna cable.
  34. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 34, Bild 1 von 1
    • Remove the screws that secure the left hinge.
  35. Dell Vostro 3450 VGA Board Replacement, Remove the Screws: Schritt 35, Bild 1 von 1
    • Remove the screws that secure the right hinge.
  36. Dell Vostro 3450 VGA Board Replacement, Lifting the Display Assembly: Schritt 36, Bild 1 von 1
    • Lift the display assembly and remove it from the computer.
  37. Dell Vostro 3450 VGA Board Replacement, Release the Latch: Schritt 37, Bild 1 von 1
    • Release the latch on the system board and then disconnect the VGA cable.
  38. Dell Vostro 3450 VGA Board Replacement, Remove the Screw: Schritt 38, Bild 1 von 1
    • Remove the screw that secures the VGA board.
  39. Dell Vostro 3450 VGA Board Replacement, Remove the VGA Board: Schritt 39, Bild 1 von 1
    • Remove the VGA board from the chassis.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 222
