Zum Hauptinhalt wechseln
Dell Vostro 3550 Disk Drive Tray Latch Replacement
Was du brauchst
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: Schritt 1, Bild 1 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: Schritt 1, Bild 2 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: Schritt 1, Bild 3 von 3
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 2, Bild 1 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 2, Bild 2 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 2, Bild 3 von 3
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 3, Bild 1 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 3, Bild 2 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 3, Bild 3 von 3
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 4, Bild 1 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 4, Bild 2 von 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: Schritt 4, Bild 3 von 3
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Abschluss
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S8G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 245
