Zum Hauptinhalt wechseln
Dell Vostro 3550 Motherboard Replacement
Was du brauchst
  1. Dell Vostro 3550 Motherboard Replacement, Unlocking the Battery: Schritt 1, Bild 1 von 1
    • Slide the release latches to unlock the battery.
  2. Dell Vostro 3550 Motherboard Replacement, Sliding the Battery: Schritt 2, Bild 1 von 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3550 Motherboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Dell Vostro 3550 Motherboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Dell Vostro 3550 Motherboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Turn the laptop right side up. Open the display to reveal the keyboard.
    • Use the metal spudger to pry the keyboard upward from the base. Make sure to pop each of the three clips keeping the keyboard in place.
  4. Dell Vostro 3550 Motherboard Replacement: Schritt 4, Bild 1 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 4, Bild 2 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Carefully lift the keyboard upward to reveal the keyboard ribbon cable.
  5. Dell Vostro 3550 Motherboard Replacement: Schritt 5, Bild 1 von 2 Dell Vostro 3550 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Lift the black tab on the keyboard cable connector upwards to release the cable.
  6. Dell Vostro 3550 Motherboard Replacement: Schritt 6, Bild 1 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 6, Bild 2 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Pull the ribbon cable away from the connector.
    • Remove the keyboard.
  7. Dell Vostro 3550 Motherboard Replacement, Remove the Screws: Schritt 7, Bild 1 von 1
    • Remove the three 7mm Phillips #0 screws that secure the access panel to the base of the computer.
  8. Dell Vostro 3550 Motherboard Replacement, Lifting the Access Panel: Schritt 8, Bild 1 von 1
    • Lift the access panel up at an angle and remove it from the computer.
  9. Dell Vostro 3550 Motherboard Replacement, Remove the Screws: Schritt 9, Bild 1 von 1
    • Remove the two 5mm Phillips #0 screws that secure the hard drive to the system.
  10. Dell Vostro 3550 Motherboard Replacement, Removing the Hard Drive: Schritt 10, Bild 1 von 1
    • Lift up the hard drive at an angle from the system and remove.
  11. Dell Vostro 3550 Motherboard Replacement, Remove the Screws: Schritt 11, Bild 1 von 1
    • Remove the four 5mm Phillips #0 screws that secure the hard drive bracket to the hard drive.
  12. Dell Vostro 3550 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 2 Dell Vostro 3550 Motherboard Replacement, Motherboard: Schritt 12, Bild 2 von 2
    • Remove the five 7mm Phillips #0 screws fastening the aluminum side panels to the laptop.
  13. Dell Vostro 3550 Motherboard Replacement: Schritt 13, Bild 1 von 2 Dell Vostro 3550 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Turn the computer over and open the screen.
    • Remove the two 5mm Phillips #0 screws to the far right and far left of the motherboard casing.
  14. Dell Vostro 3550 Motherboard Replacement: Schritt 14, Bild 1 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 14, Bild 2 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the small ribbon cable connected to the left side of the casing.
    • Repeat this step for the three remaining ribbon cables on the casing.
  15. Dell Vostro 3550 Motherboard Replacement: Schritt 15, Bild 1 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 15, Bild 2 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 15, Bild 3 von 3
    • Use the metal spudger to release the palmrest assembly from the rest of the laptop.
    • Lift off the palmrest assembly to reveal the motherboard.
  16. Dell Vostro 3550 Motherboard Replacement: Schritt 16, Bild 1 von 2 Dell Vostro 3550 Motherboard Replacement: Schritt 16, Bild 2 von 2
    • Remove the small cable connecting the motherboard to the rest of the computer.
  17. Dell Vostro 3550 Motherboard Replacement: Schritt 17, Bild 1 von 2 Dell Vostro 3550 Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Remove the ribbon cable at the far left that is connecting the motherboard to the screen.
  18. Dell Vostro 3550 Motherboard Replacement: Schritt 18, Bild 1 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 18, Bild 2 von 3 Dell Vostro 3550 Motherboard Replacement: Schritt 18, Bild 3 von 3
    • Remove the seven 5mm Phillips #0 screws that are fastening the motherboard to the casing.
    • Lift upwards on the motherboard to remove it from the laptop casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S8G6
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 1,033
