Einleitung
In this guide, we will show you how to remove and replace the Hard Drive.
Was du brauchst
Remove the screws that secure the access panel to the computer [1].
Lift the access panel partially at a 45–degree angle [2].
Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
Remove the screws that secure the hard drive to the computer.
Remove the screws that secure the hard drive to the bracket.
Lift the hard drive from the bracket.
If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Hello. Which hard drive is suitable for replacement of this particular one because mine is no longer working and I don't know anything about hard drive replacements
