Zum Hauptinhalt wechseln
Dell Vostro 3559 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 3559 Hard Drive Replacement, Sliding the Latch: Schritt 1, Bild 1 von 1
    • Slide the release latch outwards to unlock the battery.
  2. Dell Vostro 3559 Hard Drive Replacement, Remove the Battery: Schritt 2, Bild 1 von 1
    • Remove the battery from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: Schritt 3, Bild 1 von 1
    • Remove the screws that secure the access panel to the computer.
    • Lift the access panel partially at a 45–degree angle.
  4. Dell Vostro 3559 Hard Drive Replacement, Remove the Access Panel: Schritt 4, Bild 1 von 1
    • Remove the access panel from the computer.
  5. Dell Vostro 3559 Hard Drive Replacement, Removing the Hard Drive Cable: Schritt 5, Bild 1 von 1
    • Disconnect the hard drive cable from the system board and lift it up to remove it from the computer.
    • Remove the screws that secure the hard drive to the computer.
  6. Dell Vostro 3559 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Lift the hard drive to remove it from the computer [1,2].
  7. Dell Vostro 3559 Hard Drive Replacement, Remove the Screws: Schritt 7, Bild 1 von 1
    • Remove the screws that secure the hard drive to the bracket.
    • Lift the hard drive from the bracket.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 442
