Einleitung
This guide will show you how to remove the back panel of your Dell Vostro 3560 laptop to access the RAM, hard drive, and optical drive. Some of this guide was made with information from this video.
Was du brauchst
Make sure you have the right laptop by checking the sticker.
Start with your PC shut off and upside down.
Pull out tabs.
Pull up on rail to remove battery.
Remove the two screws:
One M2 Phillips screw (Fixed)
One 5-mm M2 Phillips screw
3 weitere Nutzer:innen haben diese Anleitung absolviert.
