Zum Hauptinhalt wechseln
Dell Vostro 3561 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 3561 Hard Drive Replacement, Sliding the Battery Release Latch: Schritt 1, Bild 1 von 1
    • Flip the computer over.
    • Slide the battery release latch to the unlock position.
  2. Dell Vostro 3561 Hard Drive Replacement, Slide the Battery Release Latch: Schritt 2, Bild 1 von 1
    • Slide the other battery release latch to the unlock position.
  3. Dell Vostro 3561 Hard Drive Replacement, Removing the Battery: Schritt 3, Bild 1 von 1
    • Slide the battery and remove it from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 3561 Hard Drive Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer.
  5. Dell Vostro 3561 Hard Drive Replacement, Removing the Base Cover: Schritt 5, Bild 1 von 1
    • Lift up the base cover and remove it from the computer.
  6. Dell Vostro 3561 Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Remove the screw that secures the hard-drive assembly to the computer.
  7. Dell Vostro 3561 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Slide the hard-drive assembly towards the center of the computer and lift it up and away from the computer.
  8. Dell Vostro 3561 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  9. Dell Vostro 3561 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Lift up the hard-drive bracket and remove it from the hard-drive assembly
Abschluss
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 192
