Zum Hauptinhalt wechseln
Dell Vostro 5470 Memory Module Replacement
Was du brauchst
  1. Dell Vostro 5470 Memory Module Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5470 Memory Module Replacement, Loosening the Base Cover: Schritt 2, Bild 1 von 1
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5470 Memory Module Replacement, Removing the Base Cover: Schritt 3, Bild 1 von 1
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5470 Memory Module Replacement, Disconnecting the Battery Cable: Schritt 4, Bild 1 von 1
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5470 Memory Module Replacement, Releasing the Tabs: Schritt 5, Bild 1 von 1
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5470 Memory Module Replacement, Removing the Battery: Schritt 6, Bild 1 von 1
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5470 Memory Module Replacement, Memory Module: Schritt 7, Bild 1 von 1
    • Pry the securing clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Abschluss
Johnathan Hammond
44.820 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 959
