Einleitung
The first step in any replacement of the internal components of the Dell Vostro 15 5510 is to remove its back cover. To complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. This guide also is necessary for accessing most of the internal components of the laptop.
Was du brauchst
Remove the remaining (M2x4mm) screws with the screwdriver.
Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
Pry open the top left corner of the cover with the opening tool.
Pry open the top right corner of the cover with the opening tool.
Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
