Zum Hauptinhalt wechseln
Dell Vostro 5510 Battery Replacement
Was du brauchst
  1. Dell Vostro 5510 Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Vostro 5510 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Vostro 5510 Battery Replacement: Schritt 3, Bild 3 von 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Battery Replacement: Schritt 4, Bild 1 von 3 Dell Vostro 5510 Battery Replacement: Schritt 4, Bild 2 von 3 Dell Vostro 5510 Battery Replacement: Schritt 4, Bild 3 von 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Battery Replacement: Schritt 6, Bild 1 von 3 Dell Vostro 5510 Battery Replacement: Schritt 6, Bild 2 von 3 Dell Vostro 5510 Battery Replacement: Schritt 6, Bild 3 von 3
    • Lift the battery to remove it
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Abril Alejos
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 415
