Zum Hauptinhalt wechseln
Dell Vostro 5510 RAM Replacement
Was du brauchst
  1. Dell Vostro 5510 RAM Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 RAM Replacement: Schritt 2, Bild 1 von 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 RAM Replacement: Schritt 3, Bild 1 von 3 Dell Vostro 5510 RAM Replacement: Schritt 3, Bild 2 von 3 Dell Vostro 5510 RAM Replacement: Schritt 3, Bild 3 von 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 RAM Replacement: Schritt 4, Bild 1 von 3 Dell Vostro 5510 RAM Replacement: Schritt 4, Bild 2 von 3 Dell Vostro 5510 RAM Replacement: Schritt 4, Bild 3 von 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 RAM Replacement, RAM: Schritt 5, Bild 1 von 2 Dell Vostro 5510 RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Locate the memory board.
    • Lift the Mylar to access the memory board.
  6. Dell Vostro 5510 RAM Replacement: Schritt 6, Bild 1 von 2 Dell Vostro 5510 RAM Replacement: Schritt 6, Bild 2 von 2
    • Pull the securing clips from both sides of the memory module outwards until the memory board pops up.
    • Remove the memory board from the memory-module slot.
Abschluss
J'Ara Johnson
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 112
