Einleitung
In this guide, we will show you how to remove and replace the Battery.
Was du brauchst
Remove the screw that secures the base cover to the computer.
Pull the optical-drive and remove from the computer.
Remove the screws that secure the base cover to the computer.
Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
Disconnect the battery cable from its connector on the system board.
Lift and remove the battery from the computer.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
