Zum Hauptinhalt wechseln
Dell Vostro 5560 Memory Module Replacement
Was du brauchst
  1. Dell Vostro 5560 Memory Module Replacement, Removing The Optical-Disk Drive: Schritt 1, Bild 1 von 1
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: Schritt 2, Bild 1 von 2 Dell Vostro 5560 Memory Module Replacement, Replacing the Base Cover: Schritt 2, Bild 2 von 2
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Dell Vostro 5560 Memory Module Replacement, Removing the Battery: Schritt 3, Bild 1 von 1
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  4. Dell Vostro 5560 Memory Module Replacement, Removing the Memory Module: Schritt 4, Bild 1 von 1
    • Pry the securing clips away from the memory module until it pops-up. Remove the memory module from its connector on the system board.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 108
