Zum Hauptinhalt wechseln
Dell Vostro A90 Solid-State Drive Removal
Was du brauchst
  1. Dell Vostro A90 Solid-State Drive Removal, Removing the Battery: Schritt 1, Bild 1 von 1
    • Turn the computer over.
    • Slide the battery-bay release latch and the battery-lock latch towards the outer edges.
    • Slide the battery out of the battery bay.
    • Turn the computer top-side up, open the display, and press the power button to ground the system board.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro A90 Solid-State Drive Removal, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the two screws on the module cover.
  3. Dell Vostro A90 Solid-State Drive Removal, Lifting the Cover: Schritt 3, Bild 1 von 1
    • Lift the cover off the computer at an angle as shown in the figure.
  4. Dell Vostro A90 Solid-State Drive Removal, Remove Solid-State Drive: Schritt 4, Bild 1 von 1
    • Remove the two screws that secure the solid-state drive.
    • Lift the solid-state drive out of its system board connector.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
Ein Kommentar
Remember the add the Warning steps that are found in the Service Manuals at the beginning of the guides.
Terrence15 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 185
