Zum Hauptinhalt wechseln
Dell Vostro V13 Sound Card Replacement
Was du brauchst
  1. Dell Vostro V13 Sound Card Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Vostro V13 Sound Card Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Vostro V13 Sound Card Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 Sound Card Replacement: Schritt 2, Bild 1 von 3 Dell Vostro V13 Sound Card Replacement: Schritt 2, Bild 2 von 3 Dell Vostro V13 Sound Card Replacement: Schritt 2, Bild 3 von 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 Sound Card Replacement: Schritt 3, Bild 1 von 3 Dell Vostro V13 Sound Card Replacement: Schritt 3, Bild 2 von 3 Dell Vostro V13 Sound Card Replacement: Schritt 3, Bild 3 von 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 Sound Card Replacement: Schritt 4, Bild 1 von 2 Dell Vostro V13 Sound Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 Sound Card Replacement: Schritt 5, Bild 1 von 3 Dell Vostro V13 Sound Card Replacement: Schritt 5, Bild 2 von 3 Dell Vostro V13 Sound Card Replacement: Schritt 5, Bild 3 von 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 Sound Card Replacement: Schritt 6, Bild 1 von 2 Dell Vostro V13 Sound Card Replacement: Schritt 6, Bild 2 von 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 Sound Card Replacement, Sound Card: Schritt 7, Bild 1 von 2 Dell Vostro V13 Sound Card Replacement, Sound Card: Schritt 7, Bild 2 von 2
    • Remove the black 3.0 mm Phillips #1 screw.
    • Remove the two 5.1 mm silver Phillips #1 screws.
  8. Dell Vostro V13 Sound Card Replacement: Schritt 8, Bild 1 von 2 Dell Vostro V13 Sound Card Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the white plug on the top left corner of the sound card.
  9. Dell Vostro V13 Sound Card Replacement: Schritt 9, Bild 1 von 2 Dell Vostro V13 Sound Card Replacement: Schritt 9, Bild 2 von 2
    • Use the plastic opening tool to flip the ribbon connector up.
  10. Dell Vostro V13 Sound Card Replacement: Schritt 10, Bild 1 von 2 Dell Vostro V13 Sound Card Replacement: Schritt 10, Bild 2 von 2
    • Pull the sound card out of the laptop.
Abschluss
Patrick Swaney
363 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 547
