Zum Hauptinhalt wechseln
Dell Vostro V130 Memory Module Replacement
Was du brauchst
  1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: Schritt 2, Bild 1 von 1
    • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  3. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: Schritt 3, Bild 1 von 1
    • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
  4. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the battery to the computer.
  5. Dell Vostro V130 Memory Module Replacement, Lift the Battery: Schritt 5, Bild 1 von 1
    • Lift the battery up and away from the computer.
  6. Dell Vostro V130 Memory Module Replacement, LED Cover: Schritt 6, Bild 1 von 1
    • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
  7. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: Schritt 7, Bild 1 von 1
    • Pull the LED cover toward the keyboard and remove it from the computer.
  8. Dell Vostro V130 Memory Module Replacement, Memory Module: Schritt 8, Bild 1 von 1
    • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  9. Dell Vostro V130 Memory Module Replacement: Schritt 9, Bild 1 von 1
    • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
Ziellinie
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.989 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 297
