Zum Hauptinhalt wechseln
Dell XPS 11 9P33 mSATA Removal
Was du brauchst
  1. Dell XPS 11 9P33 mSATA Removal, Removing the Battery: Schritt 1, Bild 1 von 1
    • Disconnect the battery cable from the system board.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift the battery, along with its cable, off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell XPS 11 9P33 mSATA Removal, Removing the mSATA card: Schritt 2, Bild 1 von 1
    • Remove the screw that secures the mSATA card to the palm-rest assembly.
    • Slide the mSATA card out of the mSATA-card connector.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 495
