Zum Hauptinhalt wechseln
Dell XPS 12 9Q23 Battery Replacement
Was du brauchst
  1. Dell XPS 12 9Q23 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Dell XPS 12 9Q23 Battery Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove back panel after all screws have been removed.
  3. Dell XPS 12 9Q23 Battery Replacement: Schritt 3, Bild 1 von 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Dell XPS 12 9Q23 Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Dell XPS 12 9Q23 Battery Replacement, Remove the battery: Schritt 5, Bild 1 von 1
    • Once all the screws have been removed the battery is now safe to extract
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Any tips for registering the new battery in the BIOS?
Ryan Porter - Antwort
Your battery is automatically recognized.
There is no declaration to be made in the bios.
If the problem persists, I invite you to open a support question:
https://fr.ifixit.com/R%C3%A9ponses/Devi...
Schwarzer -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 44
Insgesamt: 4,415
