Zum Hauptinhalt wechseln
Dell XPS 12 9Q33 mSATA Card Replacement
Was du brauchst
  1. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the Battery: Schritt 1, Bild 1 von 1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
  2. Dell XPS 12 9Q33 mSATA Card Replacement, Removing the mSATA card: Schritt 2, Bild 1 von 1
    • Remove the screw that secures the mSATA card to the system board.
    • Slide and remove the mSATA card out of the mSATA-card connector.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 374
