Zum Hauptinhalt wechseln
Dell XPS 13 9365 2-in-1 Battery Replacement
Was du brauchst
  1. Dell XPS 13 9365 2-in-1 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Battery Replacement: Schritt 3, Bild 1 von 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Battery Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Battery Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Battery Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Battery Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery off the palm-rest assembly.
Abschluss
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.820 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 43
Letzte 30 Tage: 163
Insgesamt: 13,836
