Einleitung
Use this guide to remove or replace this display assembly (screen) on your Dell XPS 13 9365 2-in-1 laptop. The display assembly on this laptop refers to the entire upper portion of the laptop, which houses the screen display.
Was du brauchst
Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
Use your fingertips to lift the system badge open and reveal the single case screw.
Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
Use a Phillips #000 screwdriver to remove the screw (M1.6x2.5) that secures the wireless-card bracket to the motherboard.
Peel off the tape that secures the display cable to the M.2 solid-state drive heatsink.
Use a Phillips #000 screwdriver to remove the two screws (M1.6x2.5) that secure the display cable bracket to the motherboard.
Lift the display cable bracket off the display cable.
Open the palm-rest assembly fully and place the display assembly and palm-rest assembly face down.
Use a Phillips #000 screwdriver to remove the six screws (M2.5x3.5) that secure the display hinges to the palm-rest assembly. There are three on each side.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
