Zum Hauptinhalt wechseln
Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement
Was du brauchst
  1. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 2, Bild 1 von 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 3, Bild 1 von 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement, Removing the Solid-State Drive: Schritt 8, Bild 1 von 1
    • Peel off the display cable tape from the hard-drive plate.
  9. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 9, Bild 1 von 1
    • Remove the two screws (M1.6x2.5) that secure the hard-drive plate to the system board with a Phillips 000 screwdriver head.
  10. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 10, Bild 1 von 1
    • Remove the hard-drive plate.
  11. Dell XPS 13 9365 2-in-1 Solid-State Drive Replacement: Schritt 11, Bild 1 von 1
    • Gently slide and remove the solid-state drive from the solid-state drive slot (SSD not pictured in image).
    • Solid-state drives are fragile. Exercise care when handling the solid-state drive.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 51
Insgesamt: 5,979
