Zum Hauptinhalt wechseln
Dell XPS 13 9365 2-in-1 Touchpad Replacement
Was du brauchst
  1. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 5, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 6, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: Schritt 8, Bild 1 von 3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: Schritt 8, Bild 2 von 3 Dell XPS 13 9365 2-in-1 Touchpad Replacement, Touchpad: Schritt 8, Bild 3 von 3
    • Open the ZIF latch on the touch pad connector.
    • Disconnect and remove the ribbon cable from the touch pad. The ZIF connector latch lifts up to allow its release.
  9. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 9, Bild 1 von 1
    • Use a Phillips #000 screwdriver to remove the two screws (M2x2) that secure the touch pad to the palm-rest assembly.
  10. Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 10, Bild 1 von 2 Dell XPS 13 9365 2-in-1 Touchpad Replacement: Schritt 10, Bild 2 von 2
    • Lift the touch pad from the inner edge and remove it from the palm-rest assembly.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 629
