Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
How to remove the base (bottom) cover and power light board, which must be removed to access the battery. The images and information in this guide were taken from this computer's service manual, which can be found on the product page.
Ersatzteile
Keine Ersatzteile angegeben.
  1. After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • Using a prying tool or a fingernail, lift up the base cover (#1).
  2. Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • After removing the Philips screw which holds down the power-light board (#1), remove the power light board (#2) and its cable.
Abschluss
William Daniels
693 Reputation
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 7
Insgesamt: 221
