Einleitung
How to replace the mSata SSD drive in a Dell XPS 13 L322X laptop. The images and information in this guide were taken from this computer's service manual, which can be found on the product page.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • After turning off the computer, use a Torx 5 screwdriver to remove the 10 screws (#2) from the computer's base.
    • Using a prying tool or a fingernail, lift up the base cover (#1).
  2. Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • Lift up the small latch which holds down the power-light board cable (#3) down. Remove the cable by pulling out sideways.
    • After removing the Philips screw which holds down the power-light board (#1), remove the power light board (#2) and its cable.
    • Peel the tape that is adhered over the solid-state drive.
    • Remove the screw that secures the solid-state drive to the system board.
      • Slide and remove the solid-state drive out of the system-board connector.
    • Align the notch on the NEW solid-state drive with the tab in the system-board connector.
    • CAUTION: Use firm and even pressure to slide the solid-state drive into place. If you use excessive force, you may damage the connector.
      • Insert the solid-state drive connector at a 45-degree angle into the system-board connector.
        • Replace the screw that secures the solid-state drive to the system board.
    • Adhere the tape over the solid-state drive.
Abschluss
To reassemble your device, reattatch the power board cable and screw back on the base cover.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Johnathan Hammond
Mitglied seit 28.02.2018
35.851 Reputation
408 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 255
