Was du brauchst
Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
Now carefully lift the unit from holding the heat pipe.
After the heat-pipe unit is removed, the power connector for the fan is accessible.
First remove the power connector for the CPU Fan.
Now remove the two screws connecting the CPU Fan.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
