Zum Hauptinhalt wechseln
Dell XPS 1340 CPU Fan Replacement
Was du brauchst
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: Schritt 1, Bild 1 von 1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: Schritt 4, Bild 1 von 2 Dell XPS 1340 CPU Fan Replacement: Schritt 4, Bild 2 von 2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: Schritt 5, Bild 1 von 2 Dell XPS 1340 CPU Fan Replacement: Schritt 5, Bild 2 von 2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: Schritt 6, Bild 1 von 1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,790
