Einleitung
The cooling fan is the main source of cooling for the device. It prevents overheating which can cause internal damage to the device such as the hard drive. It is highly important to have a clean and functioning cooling fan. Much of the cabling is delicate in this part of the computer. Be careful not to destroy connections to the motherboard. This guide will show you how to replace a cooling fan. You will need tweezers, a Phillips #0 screwdriver, and a plastic opening tool.
  1. Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Using the plastic opening tool, pry up the back cover. It is recommended to start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. The fan is located on the upper right hand side of the laptop. Unscrew the four 4.5mm Phillips #0 screws along the fan.
    • The fan is located on the upper right hand side of the laptop.
    • Unscrew the four 4.5mm Phillips #0 screws along the fan.
  5. Disconnect the fan connection by using the metal tweezers. Then, plug in the new or cleaned fan back into the connection.
    • Disconnect the fan connection by using the metal tweezers.
    • Then, plug in the new or cleaned fan back into the connection.
Abschluss
Cole Hanson
138 Reputation
1 Anleitung geschrieben
UW Stout, Team S8-G3, Ogden Spring 2018 Mitglied von UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 144
