Zum Hauptinhalt wechseln
Dell XPS 15 7590 Charger Port Replacement Guide
Was du brauchst
  1. Dell XPS 15 7590 Charger Port Replacement Guide, Charging port: Schritt 1, Bild 1 von 2 Dell XPS 15 7590 Charger Port Replacement Guide, Charging port: Schritt 1, Bild 2 von 2
    • Make sure that the computer is fully shut down, and remove the ten 3 mm screws around the edge of the back cover with the T4 Torx screwdriver.
    • If the computer is not fully shut down, it could lead to damage to the computer and mild electrocution when performing this fix.
  2. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 2, Bild 1 von 3 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 2, Bild 2 von 3 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 2, Bild 3 von 3
    • Lift the XPS tab in the center and use a Phillips #0 screwdriver to remove the two 8.5 mm screws underneath.
  3. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 3, Bild 1 von 1
    • Remove the back cover from the computer.
  4. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 4, Bild 1 von 2 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 4 mm screws indicated in the image.
  5. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 5, Bild 1 von 2 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 5, Bild 2 von 2
    • Open the computer to between 30 and 45 degrees.
    • This step uncovers the charger port by slightly lifting the piece you just unscrewed.
  6. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 6, Bild 1 von 2 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 6, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the indicated 3 mm screw.
    • This allows the charger port you are replacing to be disconnected.
  7. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 7, Bild 1 von 3 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 7, Bild 2 von 3 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 7, Bild 3 von 3
    • Carefully disconnect the charger port connection using a plastic opening tool. The charger port should now be free from the computer.
  8. Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 8, Bild 1 von 2 Dell XPS 15 7590 Charger Port Replacement Guide: Schritt 8, Bild 2 von 2
    • Connect the new charger port where the old one was connected so that the screw holes lines up as it was in step 6.
Abschluss
Reconstruct the computer by completing steps 1-6 in reverse order. Once the device is reassembled test to make sure the replacement of your charger port was a success.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Memphis, Team 2-4, Cameron Fall 2022 Mitglied von University of Memphis, Team 2-4, Cameron Fall 2022
UM-CAMERON-F22S2G4
2 Mitglieder
1 Anleitung geschrieben
5 Kommentare
This help me to save my gf 2000€ computer :D
Took less than 30min, piece cost less than12€, perfect :)
Thx a lot
PreD2097 - Antwort
Take note that the metal bracket at the rear where you remove 3 screws does go back down, it just requires a bit of force, also make sure to keep the screen cable above this otherwise it likely wont go back down fully
Jonny Campbell - Antwort
I am getting reports that the XPS 15 7590 does not recognize the battery charger after replacing it following the guide. This has happened to me in the past on a number of occasions. I would not recommend to buy any Dell laptops given my experience of the last 3 years with the brand's customer service and the laptop. The SDD drive was faulty since delivery and had to be changed. Later on, there were issues with the graphic card. The graphic card issue, let to the replacement of the motherboard. The charging port needed change a couple of times too. The plastic part of the component kept breaking. I had an all encompassing 3-year extended guarantee. I wonder what would have happened if I had not paid for it when I bought the laptop. I would have spent more than 2000€ on a subpar computer equipment which I use for my work. I will no longer buy any Dell laptops given my experience both with the product and with customer service. The technicians for the repairs were excellent though!
izzyVan - Antwort
Amazing, thank you! All installed and working way better than the old Jack, which degraded after 5 years.
Dan Watson - Antwort
Best guide evah! This is my first time an internet guide's pictures and text actually helped. The only issue I had was waiting for delivery of the #4 torx driver and opener. Thank you very much Jeremy et al for this outstanding guide.
Jeff Morse - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 69
Letzte 30 Tage: 228
Insgesamt: 5,510
